Dimensioning Elipse
Dimensioning Elipse
Dimensioning Elipse
How do you go about dimensioning elipses in SW drawing files?
RE: Dimensioning Elipse
You can draw a construction line across the long and short axes, trimmed against the ellipse, and dimensioning the construction lines.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
In SW05 & later, the elipse has "quadrant" points to dimension to.
It also depends how the part is going to be machined. Some NC programs will interpolate the points required for machining, others you will have to create the points.
If you are maching a true elipse you do not have radii & centrelines to dimension.
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
