HOLE CALLOUT FORMAT FILE
I have altered the hole callout format file to have "(<NUM_INST>) HOLES" at the end of each hole callout. By default Solidworks still puts "Number of Instances X" at the begining of the hole callout, which we have to delete everytime. Is there a way to get rid of the "Number of Instances X" at the begining of the hole callout?
RE: HOLE CALLOUT FORMAT FILE
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
I believe the <NUM_INST> is hard-coded into the programme & can only be removed manually. Although, some of the API gurus here may know of a way to use a macro to strip it from the dimensions.
BTW, welcome to the forum.
The number of instances is included in the hole callout if multiple holes with the same format are created in the Hole Wizard."
Good luck, remember standards are standards for a reason.
John
