Datum curve in WF (hope I'm not a nuisance)
As you know, We've just upgraded to Wildfire and there is something I've found odd. I would like to create datum curve by sketching it. However, when I pick the datum curve button/icon a pop-up options menu comes up that asks me to select one of the following:
Thru Points
From File
Use Xsec
From Equation
How can I sketch a datum curve by sketching on a plane?
You guys are always very helpful so I thank you in advance.
SrG.
RE: Datum curve in WF (hope I'm not a nuisance)
It should be the at the very top of the Datum creation toolbar, or under Insert-->Sketch.
That through me off.
I appreciate your help.
SrG.
