real assembly dimensioning
I have a bit of a small question here. I have a basic assembly with 4 components mated on a surface (basically it is a PCB encoder so the mates are surface and align acording to a 0,0 hole datum. Now I am very aware of the "show" dimension feature, and since these dimenions need to be "real" dimension I cannot add them since they need to be driven by the model parametrically and vice versa but when I go to the show dimensions and select "view" nothing really comes up... or the dimensions that I want to show do not show up at all, now when I select "part" it shows ALL the dimensions for that part. All I want is to show the X,Y dimensions from one component on my surface in accordance to the specified datum thats it. Is this much harder than it seems??
RE: real assembly dimensioning
Steve
http://www.sprdesign.com
http://www.3dlogix.com
