Hole Wizard Pipe Tap Problem
Hi guys,
Is it just me and my machine? When I call out a hole with a pipe tap my drawing shows the tap drill and depth, the dimension for the tapered reamer (which we don't use on a 1/8"n.p.t.) and no callout for the thread. Am I missing something in the set-up?
Dennis
Dennis
SolidWorks 2006 SP1
Windows XP Pro, Pentium4 3.00GHz
1.5 GB RAM, Matrox P650
Logitech Marble Mouse, CADMAN
RE: Hole Wizard Pipe Tap Problem
Further development, this problem occurs on a mirrored part. The original part works fine, it's when I try to dimension the mirrored part that the hole wizard is messed up. Is this normal or is there something I need to do to make it work?
SolidWorks 2006 SP1
