Help on Linetype ot Library's of Linetypes for AutoCAD Map 5
I am looking for a linetype that has a bold line with 3 circles (filled in). Kinda like this:
----------- o o o --------------- o o o -----------
The line would be solid and not dashed and the circles would be filled. Can this be done? Cause I am having a hard time creating it.
Please help.......
Please help.......
RE: Help on Linetype ot Library's of Linetypes for AutoCAD Map 5
Good Luck,
Carl
More suggestions?
Did you try the suggestion? I just did and it works, on the screen. The Wingdings "l" is a solid circle not an open one. I added the following 2 lines to acad.lin:
*POST_LINE,Post line ----ooo----ooo----ooo----ooo----
A,.5,-.2,["lll",Wingpost,S=.1,R=0.0,X=-0.1,Y=-.05],-.25
Then in the drawing define style "Wingpost" to use font "Wingdings". You may want to play with the numbers to get spacings and alignments just right.
Carl
