Pipe Stabbing?
Pipe Stabbing?
Pipe Stabbing?
What does "pipe stabbing" mean?  I understand it's a British or European term.
Good luck,
Latexman
RE: Pipe Stabbing?
It is not a term that I have heard here in South Africa. Perhaps you misheard someone say "stub in"?
RE: Pipe Stabbing?
stub-in/stab-in= same thing
basicaly welding small pipe into large pipe without fittings.
RE: Pipe Stabbing?
in public works in the United States - generally refers to inserting a bell end of a pipe into the spigot as you lay the pipe in the bottom of a trench.
RE: Pipe Stabbing?
cvg is right.  Stabbing is also a drilling term meaning to place the male threads of a piece of the drillstring, such as a joint of drillpipe, into the mating female threads, prior to making up tight.
http://www.glossary.oilfield.slb.com/Display.cfm?Term=stab
RE: Pipe Stabbing?
Thanks everyone.  I thought this referred to something from the oil patch.  Looks like it's common to other areas too.
Good luck,
Latexman
