Electric Motor and Control HELP!
I have an application where I need a motor (DC or AC, don't mind!)
It needs to be controlled from some unit/dial with reference to its speed ... probably between 60-600RPM.
It will be used in a dusty environment.
It will be about 50mm (2" in diameter).
I haven't a clue where to start, thats why I am here. I need some guidance - pointers on who to contact in the UK for a single solution.
What I would like to do is to specify a unti which I plug in and play!
Any help?
RE: Electric Motor and Control HELP!
Start with the basics:
How fast does it rotate?
What torque do you require?
How does the torque vary with speed?
What is your available power source?
What is the dust (explosive / flammable?)
One day my ship will come in.
But with my luck, I'll be at the airport!
