Error: NO DATA CARDS PROVIDED FOR *FLUID CAVITY
Hi, ABAQUS Users,
Based on a input file, I add the following lines to define fluid cavity(Ref node and surface have been defined):
*physical constants, absolute zero=-273.16, universal gas constant = 8.314
*fluid cavity, name=fcavity, behavior=gas, ref node=1000,surface=ASSEMBLY_SURF, ambient=1.0136e+5
*fluid behavior, name=gas
*molecular weight
0.044
*capacity, type=tabular
30
But this doesn't work in ABAQUS, the dat file generated by ABAQUS suggests:
***ERROR: NO DATA CARDS PROVIDED FOR *FLUID CAVITY
THE PROGRAM HAS DISCOVERED 1 FATAL ERRORS
** EXECUTION IS TERMINATED **
What's meaning of No Data Cards?
Any comments will be appreciated.
Yiling
*molecular weight
0.044
30
Yiling
RE: Error: NO DATA CARDS PROVIDED FOR *FLUID CAVITY
well, i had tried the same problem, and you have to let a blank line to abaqus write something!
i can't tell you right now where you have to let the blank line, but if you send me the file, i can try it.
best reguards.
first, you have to define the fluid behavior inside the instance space.
then, you define the fluid cavity outside the instance space, like this
*end instance
*fluid cavity, name=........
(blank line)
the name of the fluid behavior.
i try to explain this, but it's not so simple to do that.
i hope you can get this right.
best reguards
Thank you for your advice. I have already made it run.
Yes, you are right, we have to leave a blank line following the keyword line *fluid cavity. I am using an input file ignoring the archetecture of finite element model(i.e. instance, part, assembly). So the position of fluid cavity and fluid behavior definition doesn't matter as long as it lies inside the model data.
Are you familar with the definition of fluid property? I don't know how to define the fluid bulk modulus for incompressble fluid in a fluid-filled cavity. In theory it should be infinite. Do you have any experience to share? Currently I am using a value 2.2x10+9 Pa for water, which is obtained from the internet.
Yiling
