Polyurethane Valve Seats
What are the pros and cons in using knife gate valves with polyurethane seats for municipal sludge applications.
Obviously the suppliers talk about abrasion resistance, however I'm just curious if there are any negative aspects such as not being able to achieve a positive seal where foriegn matter (stones, fibre) causing the seat to deflect etc. Would a metal seat be a more superior unit.
Andrew
Andrew
RE: Polyurethane Valve Seats
The next thing is to look for areas where the material will pack as the valve is closing. After a couple of cycles the gate can't get to the bottom of the body.
Do you need "chest buttons", "support strips", "backing rings"? What is the bonnet packing arrangement? These people have tried everything to get a bad idea to work.
How about the ones that have rubber liners and push the process fluid out through the rubber to atmosphere with every closure. They even sell boxes you can add on to catch the crap after your floor is so slippery it is dangerous to walk on.
High performance knife gates like WEY, or ITT Fabri's new XV150 have address many of these issues but they come with a price.
So whats my solution? An eccentric plug valve, a pinch valve, anything but a knife gate...
