search for hot driven rivet fabricator
I am looking for a steel fabricator with hot driven rivet capabilities or experience. I have an historical site project and if possible need riveted structural components. I prefer a upper midwest location but finding anyone is the priority.
RE: search for hot driven rivet fabricator
The last hot rivets I saw driven was in the mid 60's on steel erection. The fellows doing it weren’t spring chickens at the time.
Do you have the tools required?
Search under Riveting Services or Structural Riveting and down on the left you can narrow those findings by state or ZIPcode.
_______________________________________
Feeling frisky.........
www.tailofthedragon.com
Rod
I found the job description for hot riveter in the Dictionary of Occupational Titles. It talked about a Pinch Riveter as a counterbalanced tool or machine that the riveter maneuvered into position to form the hot rivet end. It sounds like the tool or machine that I would be looking for. As you say the whole process is rightfully obsolete but now my interest is up. I'd like to actually see one. Thanks.
Rod
http://www.uscg.mil/hq/g-m/nvic/3_68/n3-68.htm The "art" of naval maintenance.
ht
http://www.du.edu/~jcalvert/tech/rivets.htm technical
www.ukic.org.uk/metals/rivet.doc A workshop in the UK.
http://www
h
Did you ever find anyone? Our shop in Chicago has a machine for riveting switch stands (VAE Nortrak) but we are looking for a machine here on the west coast.
Tom Stanley
My next step is to find some reasonably priced used equipment. I've found most of my ducks and need to line them up now. I could use a contact with someone with experience in hot riveting in structutral steel fabrication. It might save some me some trial and error.
Thanks to everyone who has made suggestions.
Were you able to locate anybody with Hot rivet driving experience?
I am a sheet metal specialist with experience driving iron hot rivets to 1/2'' dia. I currently live in the San Diego Ca., area, and could give hands on training to an interested party over a weekend.
However I hope that by now you have located someone.
B.E.
I will leave the notifiction turned on on this thread so when you get ready, I will see what I can do for you.
B.E.
These are what's used nowadays in many rail car applications, where hot driven rivets used to be applied. They're the equivalent of Grade 5 bolts, strengthwise.
htt
