Metallized Polycarbonated film capacitors
I am searching for the above capacitors. the application is a snubber network across a teccor/littlefuse triac. The value of the capacitor is .1uF, 400V rated if possible, surface mount preferably. I have looked at Vishay, Digikey.
First of all, do I have to go with metallized polycarbonated film for snubber network across triac.
Second of all, if not what other material could I use? Ceramic? Not sure what the characteristic difference might be?
RE: Metallized Polycarbonated film capacitors
Metallized polycarbonate have very good tolerance across their whole temp. range. Ceramic (NPO) can also have very good temp response, but finding an NPO at 400 VDC, 0.1 uF might be tough.
It looks like Vishay 632P series meet your requirements, but they are leaded not surface mount.
Peter
One day my ship will come in.
But with my luck, I'll be at the airport!
IF THERE IS 115 VOLT AC ON A CAPACITOR, THE CAPACITOR MUST BE RATED FOR AC APPLICATION.
My experience is that capacitors that are rated for 400 VDC and are used at 115 VAC will have a life of a few minutes to a few hours.
In Europe, mains-rated capacitors in small sizes tend to be marked Class X, X2, or Y according to their application. For your application it will be marked Class X or X2; Class Y types are primarily for applications connecting a line or neutral to earth (e.g. filtering).
