Energy storage and release.
This is a bit of a brainstorming exercise, so all comments are welcome:
Looking for the most compact way to store and release energy in a particular application: Here are the specs.
Less than one kg weight.
As small as possible
Less than $50 USD
Takes in mechanical or electrical energy at a max rate of 1000 watts for .2 sec
Releases stored energy in .005s at an average rate of 4kW
Efficiency > 10%
Inputs can be mechanical (rotation or linear motion) or electrical (current).
Output is linear mechanical motion, no particular stroke or force requirement, just need energy and power as spec'd.
Storage can be potential, kinetic, or electrical, don't really care as long as I can get the storage, efficiency, and fast output as listed above.
Let me know any realistic, or unrealistic ideas you may have. Thanks.
- Rich
Less than $50 USD
Efficiency > 10%
- Rich
RE: Energy storage and release.
Subspace?
TTFN
There are many makers of this item.
Here is a concept that might be applicable
http://www.tiniaerospace.com/fbapplication.html
