Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Where have you been all my life! I found the answer I needed in seconds..."
Geography
DougB (Geotechnical)
7 Nov 05 16:46
What do you consider a reasonable maximum organic content to specify for engineered fill placed under a building foundation?  Material in question is a silty clay bordering on a silt.  I am expecting 0 to 6 feet of fill under the footings (ie depth varies).  2 story wood frame construction for condominiums.
eric1037 (Geotechnical)
7 Nov 05 17:30
We traditionally recommend NOT using soil with more than 4% organics for engineered fill.
7 Nov 05 17:34
Thanks.  Material in question came in at 3% and I was thinking a 2% limit was too strict but 5% seemed a bit too lax.  So that 4% limit works for me.  I'll consider your response standard of practice :).  Kidding.  But if anyone else has a comment I'd be interested.
jdonville (Geotechnical)
8 Nov 05 9:52
DougB,
We generally recommend 3% max by dry weight. Obviously, no large organics (stumps, branches, roots, leaves, lumber or construction debris, etc.).
Jeff
Jeffrey T. Donville, PE
TTL Associates, Inc.
www.ttlassoc.com
Helpful Member!  geociv (Geotechnical)
8 Dec 05 22:13
DougB - why use a silty clay borderline silt as structural fill below a foundation?  Wouldn't a granular material be a better choice (for compaction and sturctural capacity).  Silt and silty clay are highly moisture sensitive and depending on the location of the job, the contractor could have serious compaction problems if the jobsite gets wet.  Of course, a good contractor could make the material work, but I've learned to plan for the worst case scenario (i.e., low bidder!j/k).
cbosy (Geotechnical)
15 Dec 05 17:23
I agree with the 3% under footings and maybe up to 6% under slabs that could tolerate a little settlement and cracking.
Close Box
Join Eng-Tips® Today!
Join Us             Close
