Auto length update based on sketch line?
To make my question as simple as possible, assume I have a sketched line 24" long.  Now, I have a steel rod extruded along that line that I would like to automatically update based on the length of this line.  Example, I make the line 30" long and the steel rod is now 30" as well.  It seems like a relationship could be used here somehow.  What is the best way to do this.
TIA,
Drake
When it comes to protecting yourself or your family it is better to be judged by 12 than carried by 6.
RE: Auto length update based on sketch line?
Make a 3DSketch and sweep along the line, is how I do it.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
You could use an Equation or, instead of a line, offset a plane & extrude Up to surface selecting the plane.
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
"Up to Vertex" in the Extrude dialogue's "End Condition" and select the sketch lines endpoint.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP1.0 on WinXP SP2
Doh ... I always forget the easy one. "Up to vertex" is the way to go.
Star for you Jason.
ctopher, Is there a reason to use a 3DSketch rather than a 2D?
Drake
Just thought of another way ... use the Link Values feature, to link the dimension from the line length & the extruded length dimension of the steel rod.
cygnas ... just a passing thought, but you do know that you can access & change the length of the extruded steel rod, by double clicking it ... right?? You would have to do that to the sketched line anyway!
cygnas,
I use 3DSketch because I never know when/if it will change from a straight line to a curve. Editing the 3DSketch and rebuild, the sweep feature will change. If yours will always be a straight line, then the suggestions from the others above will work great.
Chris
FAQ559-1100
FAQ559-716
Why wouldnt you just drive the length of this by the features own dimension.
Having a sketch dimension drive the length of a feature is like holding a pen in your right hand, and using your left hand to move you right hand?
Unless you are using your sketch line as an undefined line and free moving its end into position then allowing it to build.
This is ok if each different length is a new part, but if not then each length will require it own config....and a dimension to drive the length, therefore why not use the feature dimesnion as mentioned above.
Design tables may be helpful here.
cheers
Have you tried the Weldments tools yet.  It works pretty slick for extruding predifined cross sections along 2d and 3d sketches.  There should be a tutorial for it too.
