Problem Reinstalling Ver. 11
I bought a new computer. I installed MathCad 11 on the new computer and had to do a manual activation. The program now runs but when I try to open a data file, the program does not look for a .mcd file. Instead, the program looks for a "FeatureSaveAsFilters" file. I have none and can't find out what it is. I called MathSoft. They didn't know either.
I can open .mcd data files using Windows Explorer. But I can't then save them as .mcd files. The program wants to save them as "FeatureSaveAsFilters." Has anyone encountered this problem?
RE: Problem Reinstalling Ver. 11
TTFN
Dear Mr. _____ ,
As mentioned, we currently support Mathcad 12 and 13. Again, as a quick courtesy, I did a quick search for that phrase in our database and online and found nothing. So if our previous recommendations don’t work, then you’ll want to check with your Help Desk or a local computer technician.
Regards.
______
Mathsoft Technical Support
Peter
Thanks, MathSoft. You did try to help even though you only support the last 2 versions (12 & 13).
