Saving section views?
Just wondering if custom section views can be saved so that they appear in Orientation toolbar and can be viewed anytime without having to create them fresh everytime?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Saving section views?
Flores
SW2006 SP1.0
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
OR, after picking the section view and creating the section, do not close the "section view" dialog box. Look down to "Options", and pick "Save View". This ALSO saves the named view to the Orientation dialog box.
(yes, in part or assembly file)
Flores
SW2006 SP1.0
Is your section so complex that you can't do it in the drawing?
Windows 2000 Professional / Microsoft Intellimouse Explorer
SolidWorks 2006 SP01.0 / SpaceBall 4000 FLX
Diet Coke with Lime / Dark Chocolate
Lava Lamp
This is in another configuration, with the cut-extrude suppressed in all the other configurations. Also, name the view that you want of the cut and save it. Now, when you return to this configuration, you can get the same view, and if you ever want it in a drawing you can insert the named view.
One "problem" with using a saved section view in the Orientation pop-up, is that once selected, the section remains for all other standard views. It is, however, very easy to deselect the Section View icon to remove it.
Are you SURE you can't just cut a section view in your drawing?
Lava Lamp
Either way, try running a repair. See the Solidworks Installation section in the FAQs.
