Creating the multisection surface
V5R15
I am trying to create a multi-section surface as described on pg.9-32 of CATIA FOR DESIGNERS (SHAM TICKOO)V5R14. After selecting the sections and adding the coupling lines I choose the OK button, I get an error message that says A CHECK ON DATA WILL BE LAUNCHED ON ACTIVE DOC. COMMAND INTERRUPTED. I have the sections constrained as in the example shown in the book. I have tried multiple variations of the sequence shown all with the same result. I am including a screen capture, I hope.
http://i25.photobucket.com/albums/c73/BoliverT/Multi-sectionsurface.jpg
Can someone please advise what I am doing wrong.
RE: Creating the multisection surface
Could you include the image in higher resolution?
The one attached is not visible.
