ASME Code Case 2211
ASME Code Case 2211
I can not find in our library any reference to ASME Code Case 2211 "Pressure Vessels with Overpressure Protection by System Design". Is this a separate document or it is a part of the Code?
Thank you.
Thank you.
RE: ASME Code Case 2211
To supplement metengr's post, if you can't find a Code Case that has been approved, in all liklihood it has been incorporated into the Code.
RLS
So, if the code case 2211 was approved - as metengr mentioned -in 1999, it supposed to be included in 2004 Ed. of Code, but it is not there. Could you please suggest where else I might be able to find it?
Thanks.
If you are a stamp holder try your AIA or see what you can find on ASME's web site. I'm not familiar enough with the Code Case to tell you whether, how, or if it has been incorporated into the text.
RLS
It may have been reaffirned at Code Week Last week but to my knowledge it had not been incorporated into the Code. It may never be, there are some C C that will.
If you need a copy you may call your jursdiction and ask them, you should also check with them to see if they will accept 2211. Acceptance of code cases by a Jursdiction is NOT automatic.
Jstephen, of course you can't get just 1 ASME wants to sell books.
W.r.t. buying 1 Code Case - I agree with aclark that ASME is not interested in selling 1 ofs. However, you could try a company like IHS.
ht
I got to the above by searching for 2211-1 on this web page...
htt
I've also seen this referenced
"Guidance on the Application of Code Case 2211—Overpressure Protection by Systems Design"
but I'm not familiar with its content to say how good it might be....
http://w
As to whether it ever becomes part of the code remains to be seen but apparently there is a joint API/ASME committee working towards that end.
http
Take a look at the Spring 2005 - PRS Joint Meeting Minutes...
http:
and the Spring 2004 - Attachment 3 Code Case 2211...
http://com
By the way, if you happen to have a copy of the Chlorine Institutes Pamphlet 60 - Chlorine Pipelines, there is a copy of code case 2211 included in the appendix. Or if you happen to have a copy of the AIChE, CCPS publication "Guidelines for Pressure Relief and Effluent Handling Systems", they also have included a copy of code case 2211. The ones here would not be considered the latest versions but would at least give you an idea of the issues.
