Catia v4 or V5 ijk point vectors
All,
How do I get or create ijk points off xyz points? How do I print them out. Is there a macro also? Any help would be great.
RE: Catia v4 or V5 ijk point vectors
Then, you can either modify the script to add an end point, (your IJK value) or you can use the point coordinates method to select each IJK value that you want individually.
Check out CATBlog!
Thanks do you have anything for v4?
Check out CATBlog!
