Erasing dimension style
I can't delete dimensions styles in my draft templates, is it meant to be impossible or I'm missing something?
Patrick
Patrick
RE: Erasing dimension style
no, these styles, with some exceptions, are not deletable.
By why would you like to get rid of them?
dy
Patrick
here is one:
ht
dy
should be executed once on the normal.dft so that any *new* draft
will get the reduced set. Nevertheless can any user change a style
an save it under a different name. The scope is, however, limited
to that draft.
To sort unwanted ones at the end can be done this way:
- select the style
- --> modify
rename it to say ZAnsi
- OK
Now this style will be sorted by SE at the list's end
dy
Patrick
