Detention Pond Outflow Pipes
Hello all: I need some help with designing the outflow pipes of a detention pond.
The situation is that the pond has two outflow pipes draining into two different wetland systems.
I am used to designing just 1 outflow pipe and an emergency spillway, this pond has 2 pipes and 1 emergency spillway.
What would be the best approach to the design of these pipes? According to the town the pipes should be designed for the 10-yr storm.
Thanks in advance for any help.
RE: Detention Pond Outflow Pipes
It is not that diff from a single outlet.
Good Luck!
