featureworks-can default be changed from metric to english for holes?
Recently I've been using the feature works to convert models, and have been getting holes coming in as metric, which is not preferable in most of my applications. Can the default for this be changed so the holes come in as english?
RE: featureworks-can default be changed from metric to english for holes?
1) File specified unit
2) Document Template Specified unit.
So if you Document Template is using mm then your converted model will have that unit. If you want inches then make a template that is inches. You must specify that in Default Template and pick that template that you just made. Then select Always or Prompt use/user... Document Templates.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
