air to air exchanger application
Does anyone have any experience using an air to air exchanger to ventilate a tightly constructed horse barn?
The barn is located in northern Michigan and the owners are reluctant to enter into the expense of heating make up air for a ventilation system, would air to air be an economicaly feasible alternative?
I could also use a reliable source for suggested ventilation rate I've been able to find quite a bit about natural ventilation methods but little to nothing adressing mechanical methods.
RE: air to air exchanger application
Good Luck,
Greg Hansen
h
Try the above link. The website is low on content, but the contact information below should allow you to contact their technical support people directly.
Del-Air Systems
1704 4th Ave,
Humboldt, SK S0K 2A0
Tel. : 306-682-5011
The best solution might be a one-fan, recirculating heating system. If necessary, a small amount of outside air can be drawn through the suction side of the fan.
