Code seems to do the same thing over again
Hi to all, i am basically a newbie in MATLAB and i have written some code that i would think should go through a matrix and write the values i want in.
W = zeros(150);
% Give values to the 150 values of M so that we have
% 150 (x,y) to make the dataset
M = rand(2,150) * 10;
% Create the matrix
for z = 1:149
    for v = 1:149
       y_total = (M(2,v+1) - M(2,v))^2;
       x_total = (M(1,v+1) - M(1,v))^2;
       W(z,v) = sqrt((y_total + x_total)\s^2);
    end
end
Here, my idea was that i have 150 opints on a graph and all the points are held in M(a column for each x,y point). Then i would want to find the distance between each two points by doing the Pythagoras theorem in W(z,v) and store the data in the appropriate rows and columns in W. My final result is that i get the same number written 150 times in each row of the same column. What am i doing wrong? Thanks for the help :)
RE: Code seems to do the same thing over again
Well if I were you I'd write a very stern letter to Mathworks and let them know that the program is doing exactly what you asked it to, instead of what you wanted.
Try
for z = 1:150
    for v = 1:150
       y_total = (M(2,z) - M(2,v))^2;
       x_total = (M(1,z) - M(1,v))^2;
    end
end
Cheers
Greg Locock
