Bushing Material
Bushing Material
I run a couple of old BSA motorcycles and they use a plain bearing bush on one side of the crankshaft as a main bearing (the other side is a roller bearing). Since BSA went to the wall in 1973, the replacement bearings currently available are rubbish - little better than brass!
Can anyone advise what material (presumably some sort of bronze but I'm open to suggestions) would be best to have some bearings made. Rough sizes are ID 1.5" OD 1.75" approximate developed power of the engine is in the region of 50HP at 7000 rpm (all approximate) and the main bearings are about 8" apart.
I'd be very grateful for any advice.
Thanks.
Thanks.
RE: Bushing Material
Ken
Oilite Would not be suitable, too soft.
Since it is pressure fed i would use Phosphor Bronze. Be sure to have a generous radius on the oil drillings. There maybe better choices in bronze material that someone can chime in on.
I have used Phos bronze for bigend bushings in model r/c racing boat nitro engines successfuly, 2 stroke so no pressure feed at all. They survive 20,000 Plus rpm fine on 40% nitromethane.
If the crankcase main bearing bore was to small, it can be bored a little. If to big, an insert can be fabricated. Similar mods are made to 400 CI SBC engines to run 350 cranks.
Ken
http://www.ggbearings.com/
And I wouldn't do any kind of reaming on it. It is a steel ring with a PM bronze interior followed by a layer of PTFE. But, there are other kinds now and other manufactures.
Your bike might not use that exact combo of material on it's bushing. You might find an exact match there or elsewhere. I would not think they had a special compound created just for them. Special size, that is a different story.
_______________________________________
Feeling frisky.........
www.tailofthedragon.com
Thanks to all who have contributed - I'm very grateful for your input.
the design of the engine? which would be hard to solve.
Making sure the oil pressure is adequate may help the bushes life.
Ken
I have had a pressure block made to test the oil pressure blow off at the relief valve and I am also experimenting with synthetic oils but as these bikes were not equipped with cartridge filters in the supply line, I've had to resort to fitting one in the return line. This is never as successful as in the pressure side of the supply line but is better than nothing and is a necessity with oils laden with a modern additive pack.
Again, thank you for your input and please don't stop questioning my methods or motives - it's all too easy to become blinkered without anyone to bounce ideas off!
Many thanks.
Mike.
Could have been AB1, AB2, or CMA1, which is a manganese aluminium bronze. Have a search through the material specs which there are many on the net and see if they can help jog your memory.
Testing the the oil relief valve pressure is a good start, but more important would the running oil pressure, especially when hot. The valve only regulates max pressure, and stays shut at anything below.
Hope this is of help
Ken
Thanks for your help.
I would have placed my money on it not being CMA1 !
not that i am a betting man!
I cast r/c racing boat props using CMA1. is was designed especially for props, being quite fluid when molten so it fills molds well. Very slightly stronger than AB2, but just as difficuilt to machine!! never heard of it used as a bearing material, nor seen it available in any forms other than ingots, but not to say it isnt available!!
ahh the fun of playing with old english bikes!! not me, but have a mate who loves his Ajs
Ken
yes, worn bearings do have a tendency to reduce oil pressure but that's why I'm after the best material I can find to help reduce the wear. When I rebuild an engine I know the tolerances are good - by the way, my enquiry relates entirely to engines I rebuild and I do not mean to suggest that I'm looking for the panacea of all ills with everyone else's engine!
Anyway, it rather seems a phosphor bronze bearing is as good as I'm likely to find! I don't mind experimenting with materials but it's the time involved in extrapolating the results!!
Cheers,
Mike.
Don't cling desparately to the journal size. The crank journals must be round withing 0.0005 inch, straight and concentric, around 10 uinch finish, and be directionally polished to avoid the "petting a porcupine" effect busting thru the oil film in times of trouble.
A full circumferential groove in either the crank journal or bearing bore reduces the load capacity a lot.
Are the rod journals fed oil thru a small journal outboard of the main ?
Thanks for that. Yes, the main journal has an oil groove and the big ends are fed from a drill way from the main journal - but that's the engine design and short of fitting a race bearing in way of the timing side journal and a quill to take the oil directly into the big ends, there's not a lot of scope for change! I'm not so much after radically altering the engine, just want to keep the old ones running for as long as possible on the best possible materials.
Mike.
