Pumping methanol and low viscosity fluids
Does anyone have experience or recommendations on equipment selection for the pumping of methano? We are looking at a process to burn methanol and need to deliver approximately 5,000 gallons/hr, up to a pressure of about 400 psig outlet.
What kind of pumps, metering, etc. would be used in such a case? (We have experience with pumping fuel oil, but not such low-viscosity high vapor pressure liquids)
RE: Pumping methanol and low viscosity fluids
The vapor pressure isn't really a problem other than ensuring you provide sufficient NPSHA to the pump when you do the piping/storage design.
For a meter my first choice would likely be an orifice meter but your accuracy requirements is a key point which you haven't mentioned.
The flow's high enough that a PD pump like a diaphragm metering pump large enough to do the job will cost you a fair bit of money. But they'll work reliably if you design the suction piping properly.
The Sundyne turbine pump mentioned is also an option, as would be a "side channel" multistage centrifical such as those used for boiler feedwater applications. But it is quite a high pressure and the efficiency will be poor in either case.
Have you considered a "sliding vane" pump ?
See the "pumpschool" dissertation on fuction, advantages etc.
http://www.pumpschool.com/principles/vane.htm
http://www.pumpschool.com/intro/selection.htm
Also:
http://www.mcnallyinstitute.com/12-html/12-03.html
http://www.blackmer.com/myapp/pdf/bul30.pdf
I have had very good luck with the Blackmer PD vane pumps in low viscosity applications..
Is this worth a "star" ?
-MJC
Thanks for the tip. yep, worth a star.
T2DK
This is a continuous duty operation.
Thanks for your help.....
