Batch Analysis Catia v5 automatically with input file??
Hi, I'm a bit new in Catia v5 and i'd like to know if it is possible in catia v5 to run automatically an input analysis file from dos without having to put on the run button. I've found how to start the input file but he doesn't run the analysis automatically. (!cnext -object "C:\testbatchcatia\Analysis1b.CATAnalysis")
Thanks for the help
RE: Batch Analysis Catia v5 automatically with input file??
Have you tried using the AnalysisUpdateBatch from the Batch Management?
(Start/Programs/CATIA/Tools/Batch Management)
Hi
Thx, but i found another way.
I've made a macro that runs it all but I don't know the script for closing CATIA.  this is my script:
Sub CATMain()
Dim CATIA As Object
Set CATIA = CreateObject("CATIA.Application")
With CATIA
    .Visible = False
End With
Dim documents1 As Documents
Set documents1 = CATIA.Documents
Dim analysisDocument1 As Document
Set analysisDocument1 = documents1.Open("C:\...")
Dim analysisManager1 As AnalysisManager
Set analysisManager1 = analysisDocument1.Analysis
Dim analysisModels1 As AnalysisModels
Set analysisModels1 = analysisManager1.AnalysisModels
Dim analysisModel1 As AnalysisModel
Set analysisModel1 = analysisModels1.Item(1)
Dim analysisCases1 As AnalysisCases
Set analysisCases1 = analysisModel1.AnalysisCases
Dim analysisCase1 As AnalysisCase
Set analysisCase1 = analysisCases1.Item(1)
analysisCase1.Compute
Dim analysisSets1 As AnalysisSets
Set analysisSets1 = analysisCase1.AnalysisSets
Dim analysisSet1 As AnalysisSet
Set analysisSet1 = analysisSets1.ItemByType("StaticSet")
Dim analysisImages1 As AnalysisImages
Set analysisImages1 = analysisSet1.AnalysisImages
Dim analysisImage1 As AnalysisImage
Set analysisImage1 = analysisImages1.Add("StressVonMises_Iso_Smooth", True, False, False)
Dim fileSystem1 As FileSystem
Set fileSystem1 = CATIA.FileSystem
Dim folder1 As Folder
Set folder1 = fileSystem1.GetFolder("C:\...")
analysisImage1.ExportData folder1, "ExportDataFileOplosSlat3b", "txt"
Dim analysisImage2 As AnalysisImage
Set analysisImage2 = analysisImages1.Add("Stress_Symbol_PpalTensor", True, False, False)
Dim fileSystem2 As FileSystem
Set fileSystem2 = CATIA.FileSystem
Set folder1 = fileSystem2.GetFolder("C:\...")
analysisImage2.ExportData folder1, "ExportDataFileOplosSlat3c", "txt"
Dim fileSystem3 As FileSystem
Set fileSystem3 = CATIA.FileSystem
Set folder1 = fileSystem3.GetFolder("C:\...")
Dim analysisPostManager1 As AnalysisPostManager
Set analysisPostManager1 = analysisModel1.PostManager
analysisPostManager1.AddExistingCaseForReport analysisCase1
analysisPostManager1.BuildReport folder1, "C:\...", False
Dim specsAndGeomWindow1 As Window
Set specsAndGeomWindow1 = CATIA.ActiveWindow
specsAndGeomWindow1.Close
Set analysisDocument1 = CATIA.ActiveDocument
analysisDocument1.Close
??????Catia.Close ???? this doesn't work
End Sub
Thanks, but i've found it.
