suspension settings affect on hydroplaning
I am familiar with how many suspension settings affect a cars handleing on dry pavement, and while cornering, but how do the settings affect hydroplaning? I recently replaced the struts on my car (96 dodge neon) and set my camber to max negative (7deg ish)till I get an alignment (next weekend) and have noticed that I seem to be hydroplaning worse than before. this has me wonderning how various suspension attributes (such as camber, caster, toe, scrub radius, bound, and rebound) affect hydroplaning.
RE: suspension settings affect on hydroplaning
Hydroplaning...dunno. Technically, 7 degrees ought to reduce the size of the contact patch thereby reducing hydroplaing. However, this condition might not allow the tire to work as designed.
I suggest a more reasonable camber value...1.5 degrees feels better to me. This is still a bit aggressive if driven daily on the street...unless you do not care about tire wear?
Michael
Norm
I'll buy that.
yes I know the alignment won't fix my bald tires. Im changing my alignment from factory settings and wanted to be sure I wasn't missing something important for wet weather traction.
In western Oregon the weather man comes on the news in October to inform everyone that it will rain till mid June and that he will be on vacation somewhere sunny till then. :)
