float contact controls
I'm installing a couple of floats in a process water pit. I need the floats to active a light and turn a pump on. Is this possible with one float? I guess to make it clearer, can you control two seperate items with one float??
Thanks in advance
RE: float contact controls
If the float has multiple contacts you can do that directly.  If the float only has one contact, use that contact to drive a relay and let the relay control the other items.
Using an interposing relay would be good practice anyway: relays are usually cheaper and less hassle to replace when, for instance, a pump motor fault occurs and passes a high fault current through the switch. If the pump is anything over a couple of hundred watts you should be using a contactor for switching the pump instead of a relay. You could drive the lamp from a spare pole or auxiliary switch mounted on the contactor.
You could in theory just parallel the lamp and the motor if they were of compatible voltage, but this would be a real cheap and dirty way to do things.
One day my ship will come in.
But with my luck, I'll be at the airport!
There are mechanical float switches that provide an adjustable dead band of operation, so that you can use one device that has a single contact which closes when the level reaches "X" height, but does not reset (open) until the level is "X + Y" height. This technical information article explains how they work and what the issues are to applying them, but you can find other manufacturers by looking for "sump operation" level controls.
[quote http://www.ab.com/en/epub/catalogs/12768/229240/2286210/229278/tab3.html] AB Float Switch article link [/quote]
Eng-Tips: Help for your job, not for your homework  Read FAQ731-376
