Note Favorites
Note Favorites
Note Favorites
I'm creating new document templates for a start-up and want to incorporate the note favorites in the process.  I have a list of ~ 150 notes (in a Word doc) that I want to make available.
Is there a faster way to enter each note than the help says?  Do I have to enter each one individually?
Any other tips for using note favorites would be great.  I haven't used them before.
Leslie
RE: Note Favorites
You may want to look at drawing blocks as an alternative to note favorites.  I think it's more what you are looking for.
Rob Rodriguez CSWP
www.robrodriguez.com
SW 2006 SP 1.0EV
RE: Note Favorites
I don't know of any way to add the notes 'en masse', but you should also take a look at using the Annotations in the Design Library.
Each existing note could be copy-n-pasted from the Word doc, into a SW drawing note. Once in the drawing RMB on each note & select Add to Design Library. The notes can then easily be drag-n-dropped onto other drawings.
New folders can be created, under the Annotations folder, to help sort the notes.
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
RE: Note Favorites
I just copy/paste my Word documents rght into my drawing.
They're all OLE objects & play nice together.
Windows 2000 Professional / Microsoft Intellimouse Explorer
SolidWorks 2006 SP01.0 / SpaceBall 4000 FLX
Diet Coke with Lime / Dark Chocolate
Lava Lamp
