NPN Transistor Array 2n2222
I am looking for a NPN Transistor array with internal characteristics similar to the 2n2222 NPN BJT. Any suggestions? I have seen by www.intersil.com CA3083, but I only need two transistors.
thanks
thanks
RE: NPN Transistor Array 2n2222
Gunnar Englund
www.gke.org
The LM394 is a fairly typical device, but it doesn't have the current handling of the 2N2222. As skogs says, monolithic pairs with high current capability are unusual - they usually found in small-signal precision applications. You'll probably that a cheap array is easier to find and less costly than a monolitic pair.
One day my ship will come in.
But with my luck, I'll be at the airport!
http://www.fairchildsemi.com/ds/FM/FMB2222A.pdf
MCC Semiconductor:
http://59.120.39.77/mccsemi/mmm_33.asp?id=336
ON Semiconductor:
http:
These are just a pair of 2N2222 dice in the same package. They will track with temperature somewhat, but don't expect monolithic matching like the CA3083 or the LM394.
