String manipulation error
I am having trouble with a string manipulation. I know this works on my computer but when I bring it to another computer to perform the string manipulation it displays an error message. Here is the callout
   bufferin2 = Left(Right(bufferin1, 8), 6)
Here is the error message:
Compile Error
Can't find project or library.
Ant recommendations
RE: String manipulation error
I'll give you the "standard" answer but this may or may not be the problem.
In the VBE, select Tools|References.  In the dialog that displays you should see something like the following libraries checked (these are the minimum libraries that should be present):
Visual Basic For Applications
Microsoft Excel x.x Object Library
OLE Automation
Microsoft Office x.x Object Library
where x.x depends on the versions of Office & Excel (for Office 2000 this is 9.0).
The Left & Right string functions are in the Visual Basic For Applications library.
Look specifically for any library that is prefaced with the word MISSING
Hope this helps,
Mike
Thanks. That was it!!!
