Using a sketch as reference for multiple parts
Greetings Wise Ones,
I am curious if it is possible, and how to create a single sketch and then use it to create multiple parts that are designed around the primary sketch? Example, if I draw a box, then offset it. I need to then make 4 separate legs that follow the box profile. I would like to use the Include command to use some of the profile and then fill in the gaps. I could create the sketch each time for 4 different parts, but am looking to see if there is a way to reference or copy a sketch or feature from one part to another. Please educate me on this.
RE: Using a sketch as reference for multiple parts
If you check out the help file and search for assembly layout, that will point you in the right direction.
Jim
