Full round between three surface
How I can create in UG full round between 3 surface ? It possible? Now i use for this I-DEAS v11(three surface fillet feature) or CATIA v13 (threetangent filet feature).
RE: Full round between three surface
Keep in mind, the steps may have changed for NX3 or beyond.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
P.S. Sorry my bad english
If you want a curvature continous 3 surface blend, then use associative bridge curves or associative splines to build the wireframe of the blend, then make a through curve mesh free form feature or use Shape Studio's Studio Surface.
As far as I know, I don't believe either of the blends you listed above in your first post have curvature capabilities, do they? If so, then why is one called tri-tangent? ;)
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
1- the problem of drawing the correct midsurface-parting curve may be solved by using an isoparametric curve with u (or v) equal to 0.5.
2- I'm used with hydraulic turbomachinery, so maybe this problem affects only flow of compressible fluids, but in our field the LE curvature continuity is never a "must": are you absolutely sure that a D2 discontinuity would affect LE performance, as far as D0 and D1 continuities are guaranteed?
3- Anyway, for this particular task I would prefer the method described by nkwheelguy: much more control, and it allows LE shapes different from the single-radius round (ex: parabolic, ogival, etc...)
