Retaining Wall w/ Piles
Currently I am working on a retaining wall, but due to the loading and limitied land, I am looking into designing a retaining wall, with a concrete beam instead of the footing which connects to piles. I have been looking at different references and I am gathering information. But I have not been able to find a reference that shows the design process for this concrete structure (retaining wall, with a concrete beam instead of the footing, and piles for the lateral loads).
I would really appreciate if you guys can advice me of a reference I can look into to help me out with this design.
RE: Retaining Wall w/ Piles
They have a much lower concentrated load.
I obtained a copy of Peck, Hanson and Thornbur. The Isolated Column Footing on Pile on Section 23.6 of page 379 has a footing instead of a beam. Also The Pile-Supported Retaining Walls Example on Section 26.8 of Page 428 also has a footing instead of a concrete beam.
Do you guys think this is something I can work from, or do you guys have any recommendations of another reference that has more inline with what I am working with.
THANKS
THANKS
Richard A. Cornelius, P.E.
WWW.amlinereast.com
