Voltage Comparator driving EM Relay
Are there any voltage comparators ICs that drive electromechanical relays?
RE: Voltage Comparator driving EM Relay
You can get solid state relay (SSR) which can be driven
by a comparator  or ose a single transistorot FET to interface it.
Send specs.
<nbucska@pcperipherals DOT com> subj: eng-tips
read FAQ240-1032
Seems everyone is looking for a simple way to drive a relay compared to a reference voltage.  Here's another Stupid Engineer Trick, use a zener.  Well a fancy zener, like a LM/TL431.   This amplified 2.5V zener is adjustable up to 36V and will drive over 100ma.   Add a pot to the adjustment pin and feed a voltage to it.  When that pin voltage exceeds 2.5V the zener conducts driving the relay.  Just need to make sure that the supply voltage minus 2.5V is enough to drive the relay.  Big problem is there is no hysteresis and the monitored voltage has to be over 2.5 volts.  In many aplications this may not be a problem.  I find it an easy way to drive an LED to indicate when a voltage is over a certain level.  Three pins and 15 cents!
