Air ûcooled heat exchangers for general refinery services
API 661 “ Air –cooled heat exchangers for general refinery services”-1997 states in paragraph 11.2.3: All tubes not strength welded to the tube sheet shall be expanded and seal welded.
Does any one know why?
Is it acceptable to have the tubes just expanded? Or the seal weld is mandatory?
When there is a big temperature differential between tube inlet and tube outlet should the inlet header box be independent from the outlet header box?
An answer from the forum would be appreciated,
Luis Marques
Luis Marques
RE: Air ûcooled heat exchangers for general refinery services
Normal API requirements for tube to tubesheet connections are:
strength welded or rolled or seal welded as per par 9.3 (new API).
My understanding is that tubes should be strength welded to tube sheet only if specified by the purchaser. In high pressure Vacuum Hydrobon service I don’t think it would be necessary to have tubes strength welded to tube sheet. Normal expanded tubes to tube sheet would be enough in a Vacuum Hydrobon service.
For high temperature differences between inlet and outlets should be accommodated in a split header design that allows for thermal expansion. Normally two header boxes suffice one on top of each other.
Luis Marques
