Safety distances for storage vessels
I have produced water/skimmed oil floating roof tanks 40ftDx40ftH with Fuel Gas blanketing at low pressure.
Question: Should they be treated the same as crude oil storage in relation to siting.i.e. what distance from roads, boundary fence and process equipment????
RE: Safety distances for storage vessels
If you want to play it safe then use the spacing requirements listed in the NFPA code assuming it is a hydrocarbon storage tank.  The hydrocarbon being whatever is present in the mix.
I suspect that you have more than just a trace amount (ppm magitude)of hydrocarbons which is why you have a gas blanket on the tank.
