Long stringy chips while boring
I'm trying to bore out a 3.5" ID steel tube. I'm having a tough time with the stringy chips getting wedged between the part and the tool. I'm using diamond shaped carbide inserts with built in chip breakers but they aren't breaking the chips. Any ideas out there for breaking the chips?
RE: Long stringy chips while boring
Manufacturing Freeware and Shareware
http://mrainey.freeservers.com
triangular tip boring bar with 04 tool nose radius. For roughing you want 0.25mm feed, leaving between 1mm or0.5mm
in bore for finishing
