How to retain points on curves during modifications?
Here's one of my biggest beef about UG since I've been using it. When I place a point on a curve - whether it's at the end points, intersecting another entity, or at some ratio - the points do not stay with the curve when the curve is modified. The point just stays at its original spot. This makes surface modeling and part revisions very difficult because I have to edit every child feature downstream because they lose their references to those points. Is there a way to place these points so they are parametric?
Thanks.
Thanks.
RE: How to retain points on curves during modifications?
Maybe there is a better way to get the same end result with less edits.
I have 2 parallel curves and at each end of the curve is an arc section connecting them. Now I put a .25 U parameter point on the parallel curves. I then put a different arc section connecting the new points. If I move the parallel curve farther apart, non of the section arcs or points move with it. I have to edit each of the arc sections every time the parallel curves are modified. Anyway to make them always attached?
Take care....
Thanks all.
Take care....
