Streamlined Tube
Streamlined Tube
I'm trying to get some streamlined tube to mount an antenna on top of; sigh, the gory details are I have to position a TCAS antenna roughly 2' above the airplane skin (to clear a radome that we're adding; yes, it has to go here).
Don't care about material (Al, Steel)
Not too fussy on gage (in my mind, not a pleasant place usually, i'm thinking of 0.063" 2024)
Minor diameter something like 3"
Major diameter something like 6"
only need 2' - 3' length
a paper trail would be nice (but not essential)
this project is not civilian certified
you're my last chance, before we fabricate something ...
purchasing says it unavailable,
some micro-light leds lead to nothing ...
any help, gratefully appreciated
RE: Streamlined Tube
http://www.vortechinternational.com/
0012 = symmetrical blade profile.
If you need something thicker Google for "0018" rotor blades - unusual but maybe they exist.
Dave
http://www.wipaire.com/
http://www.kenmoreair.com/index.php?flash_loaded=1
Cheers
Greg Locock
You might look at mast extrusions for sailboats, a Kenyan 3650 is 5x3.5 They are usually 6063 t6 or 6061 t6
They also have an airfoil spreader section SP 6 which is 6.5x1.75 with a .125 wall. Check www.RigRite.com/spars
Hope this helps,
Brian Evans.
I'd fight like hell to do anything other than that. Put it on the vertical stab, the nose radome, or maybe dual antennas with a splitter so one makes up for the other when it's shaded.
Steven Fahey, CET
To get such a tube of 3" x 6" diameter, you would first make up a tube 7.5" diameter by whatever length you need, then scribe parallel axial lines 6.96" apart on its surface, and slice it on those lines, producing two partial cylinders and some scrap. In cross section each partial cylinder would resemble an arc of 3.75" radius by 106 degrees.
When we first made them, my tube mill, Francis, actually made up full tubes and sliced them. Later he found a way to roll the partial tubes directly. Work with your tin shop; it's probably easier for them to make a similar tube with a short straight tangent (length determined by the size of their slip roll) than to make them fully curved.
In 12 gage stainless, it's simple to butt the edges at the inner surface and bond the pieces with small fillet welds, producing a tube with a shape like this: ()
In the foil that airplanes are made out of, it would be a little more difficult, but a decent TIG welder could make it look real nice in .063" steel.
Mike Halloran
Pembroke Pines, FL, USA
You never gave us a clue as to the operational environment this antenna mast will see, such as:
V(TAS,IAS)max
G(X,Y,Z)max
H(altitude)max
T(temperature)min/max
Evironment [desert, arctic, oceanic, rain-size/rate, icing, lightning-strike(?), etc]
Install life: Test program X-hours-service and 6-months: or remaining service life of acft such as 25,000+-hrs and 30-years???
Vibration environment?
Regards, Wil Taylor
no, i didn't ... the plane isn't black, but it is dark grey; that 's why i didn't think the operational environment was particularly relevant. we tend to err of the heavy side of things, and can afford special inspctions ... lucky us, eh !
this plane will probably ('cause i don't really know !) operate similar to a commercial transport, in terms of mission profile; limited flying time is expected (hangar queen).
right now i'm tending towards a fabricated solution, welded or riveted (depending on the shop's feeling on the day). probably a 4" - 6" diameter tube (6061 if we're welding), 0.06" - 0.08" wall, and similar thickness sheet for the fairing.
cheers
First. A "no-kidding" story...
I worked with a bunch of Army guys on a limited mod (such as Your'es), for putting Rotor blade sections into a real-world icing situation. The Test-set-up hung the blades off the side of Beech King-Aire with an "aerodynamic" frame-work around them. My mechanical/structures review before flight indicated it was structurally questionable and potentially too flexible. I recommended a critical review by the "vendor" who designed and built it [I will NOT say which company it was]. The review resulted in minor beef-ups here/there on the frame work and strut. After just a short winter-flying season (about 75-hrs) the Army guys removed it from the acft. I was asked to inspect and evaluate the structure: since a few "small cracks" were noted. A FEW SMALL CRACKS MY ASS... every part [skins, ribs, spars, fittings, boom-arms, actuator attachments, etc] showed signs of cracking, severe fretting, distortion, or loosened fasteners. I recommended scraping ever piece of the equipment... and suggested they NOT use the same design-fabrication shop, EVER again [industry reputation NOT withstanding... the company did a lousy job on that equipment... probably put a junior engineer on the task].
NOW...
The 24-inch antenna stand-off You need (adjacent to another external body) in a "generalized transport flight environment" would make me nervous to say the least. Buffeting/vibration/flutter/fatigue, rain/ice, thermal cycles, bird-strike, lightning-strike, bonding/groundin for static dissipation, etc... make this a dicey issue to evaluate at best.
RB'57... a question (food-for-thought): if the mast fails, or is damaged, in a least opportune time in-flight [or a during a critical mission-task, etc]... what is the greatest harm it COULD it do (to the acft or the mission)????
Sorry if I come-off a bit "hard" sounding... my military aero-experiences have led me to [absolutely] believe that "Murphy was an optimist".
Regards, Wil Taylor
http://www.eng-tips.com/viewthread.cfm?qid=67807
The lesson I learned is to use horribly large margins built on extremely conservative assumptions, and then back it up with boilerplate to make absolutely sure. It seems people just have to have these kinds of antennas.
Steven Fahey, CET
