Solid edge and Oracle
Hi
My boss recently advised me that we are changing our database software to Oracle. Also he is asking me to connect solid edge to it. Since I don't know Oracle I would like to know if it's possible and what it takes to accomplish it.
We are using SE V17.
Thanks in advance.
Patrick
Thanks in advance.
Patrick
RE: Solid edge and Oracle
All the tools built into solid edge for file management are based on SQL.
What exactly is he trying to connect?
--Scott
--Scott
For some pleasure reading, try FAQ731-376
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
I'm not familiar with the programming side of this so is there a simple solution or I need some third party to do this.
Patrick
Team Center Express is not able to communicate with a variety of databases like Team Center Engineering or Enterprise. That is one of the Express enhancements to make it easier to use/install/get started right away. Team Center Express only works with SQL.
Having said that, and to comment on your latest post, Patrick, there are several SE users who have written custom API (programs) to pull the BOM data from SE and convert it to an ERP system, often running on Oracle. There is also a more manual way of exporting the BOM as a text document and then importing that into your database.
--Scott
