Commercial Quality Steel?
What is CQ steel? I believe that is stands for commercial quality, which leads me to my next question. What is commercial quality steel? We use a lot of A-36 steel plate, and I wanted to know if anyone could compare these different grades of steel for me. How does it compare in strength, hardness, weldibility, formibility, surface finish, fatigue strength, abrasion resistance, impact resistance, and of course price. Is this HR or CR? pickled? oiled?
We are looking to build a shaker conveyor that is about 50 feet long and has a pan constructed of 1/2" plate. It is 36" across the bottom and has a 6" leg turned up on each side. We need a plate that can be formed, welded and can withstand the shock and vibration associated with a shaker bed. Any suggestions?
We are planning on lining the the bottom of the pan with AR 400 plate.
RE: Commercial Quality Steel?
In our high impact applications the ENDURA lasts more than twice as long as AR400 so it becomes more economical once we start replacing worn parts.
