Heat Sink Fins
Heat Sink Fins
Hello All,
I am doing some experiments with heat sinks so that I can find a high efficiency design for my application.
I was talking to a mech friend about heat sinks and making them more efficient and he said that the CONICAL shaped fin is better than the TRIANGLE shape. He also said that the spacing between the fins made a difference. Is this correct? Any other help on heat sink design would be much appreciated!!:)
RE: Heat Sink Fins
RE: Heat Sink Fins
RE: Heat Sink Fins
ko (www.ecooling.biz)
RE: Heat Sink Fins
RE: Heat Sink Fins
Does the fan you defined match your test fan?
Does the duct you defined match your test duct?
Does the fin thickness you defined match your test sample?
I'll be happy to check it out if you send me your hsd file and test results.
