gas pipe sizing
gas pipe sizing
gas pipe sizing
how is gas pipe sizing done (gasses like LPG etc...)?
where can I find info in this regard?
RE: gas pipe sizing
Local fuel utilization codes will have the tables in them.
RE: gas pipe sizing
mechanicaldup,
LPG should be liquid phase.
RE: gas pipe sizing
The same as any other gas or liquid.  Of couse if you have 2 phase flow then it is a bit more complicated.
Like Pan said, determine if you have a liquid or vaporized state before you start.
RE: gas pipe sizing
I'd suggest Crane TP410 as a good starting point.
Be aware that gas equations use Pabs.
