Suggestions on an MRP System need to chose
Can everybody give their own suggestion of which MRP is suitable for a sheet metal industry. fabricating manufacturing and distributing
Mechanical Engineer
RE: Suggestions on an MRP System need to chose
Mechanical Engineer
Getting my personal caution statements out of the way. There are several large players in MRP/MRPII/ERP Oracle, JD Edwards, Peoplesoft, SAP, IBM. Expect relatively high costs. There are many different smaller packages with varying degrees of functionality. You will have to go through the sales spiel and decide which package suits your business. Capabilities of the different packages change over time so unless someone is reviewing the different packages on an ongoing basis you will have to review yourself and make a decision on your own criteria. Check you cost to benefit numbers and undstand you will have to add people to support whatever package you decide to purchase.
Good luck.
http://www.pcmrp.com/
