4130 cr vs 4340 forged
I would like to compare the use of a (1) pump crankshaft fabricated (welded) with a 4130 cold rolled steel shaft and 4130 cold rolled lobes; to a (2) pump crankshaft (welded also) with a 4340 forged shaft and 4340 forged lobes. both cranks stress relieved.
RE: 4130 cr vs 4340 forged
What section thickness?
Was the welding done with the proper pre-heat/postheat/etc... welding practice and filler rod?
Now, taking the comments by NickE and adding the welding piece, you need to decide what you need to compare between these different alloys and wrought product forms. I would presume you need to evaluate tensile/yield strengths and fatigue strength for your application.
Mechanical properties for the alloys you listed (4130 and 4340) will respond differently to heat treatment because of the difference in alloy content, so check into the heat treatment condition of both product forms.
