Combining parts in an assembly
I was wondering if anyone had any idea how to combine parts within an assembly.  It seems to me that the only way to make one part out of two is within a part, not within an assembly.  I figured there has to be a way to make all of the assembly parts one part for FEA etc.  The combine command only appears when i'm editing an individual part, outside of the assembly.
Jesse
RE: Combining parts in an assembly
"Save as" -> Part
open part -> combine (bodies)
should do the trick (be sure to save the bodies)
Stefan Hamminga
Mesken BV
2005 Certified SolidWorks Professional
Mechanical designer/AI student
It's been a while since I've done this, but I believe you edit one part and use the Join feature in the context of the assembly.  Check Join in help and see if that's correct.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Insert>New part
Give the part file a name, while in edit part in context in the assembly go to Insert>Features>Join
Pick the Parts in the assembly that you want in the new part file, once you hit ok it will automatically boolean them together (as long as the parts picked are touching or intersecting)
W.Y.T.D.N.T.Y Manual coming soon :)
"if you can't make it work...Cheat"
Will this new solid update as the individual component parts update?
You can also CNTRL or SHIFT-Select components in the Assy and "Form New Sub-assembly Here".  These components will update with component part changes.  I am unsure when you use the Join command (I don't use it enough).
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
I think he wants to run COSMOSXpress on an assembly. That's why I suggested the 'save as part' method, to get one single body.
Stefan Hamminga
Mesken BV
Joining worked....
Im going to export as an iges or step and run a frequency analysis in algor
thanks for the help
