70/30 Cu-Ni use in sour environment
hello all,
I would like to ask the suitability of using 70/30 Cu-Ni piping in the sour environment and in the applications below.
thank you.
COOLING WATER, OPEN DRAINS (OILY),
CHEMICAL DRAINS, TREATED SEA WATER,
UTILITY WATER, OILY WATER,
BRACKISH WATER , WASH WATER,
FIRE WATER (BRACKISH)-BELOW GROUND DUTIES ONLY PRODUCED WATER
FIRE FIGHTING FOAM - BELOW GROUND DUTIES ONLY PROCESS CONDENSATE
BRINE WATER, EFFLUENT WATER,
DEDICATED DRAINS, WASTE WATER,
OILY BRINE,
thank you.
OILY BRINE,
RE: 70/30 Cu-Ni use in sour environment
you may find the data you need at the following:
http:/
I hope it helps.
I scanned the link you provided, it helped me lot thanks.
I also need the wall thickness values for 1/2, 3/4, 1, 1 1/2 and 2 inch pipes for these applications.
If you need to calculate wall thicknesses and do not know how, then I very strongly suggest that you find an engineer experienced in this field, hire them, and pay them appropriate engineering fees.
Exists as: SB-466 seamless pipe and tube, and as SB-467 welded pipe.
For some further information:
http://w
http://www.nbm-houston.com/c706_specs.html
For detailed design and calculations, you are on your own.
Good luck!
I got what I want
